My problem was "solved" by thoroughly descaling the OPV (removed from machine) but I could not then and cannot now "connect the dots" as to how this solved the problem.
I now believe it is caused by an intermittent electrical problem INTERNAL to the Ulka pump - that being an intermittent failure of the diode which functions as an electrical check valve. I would not think that a diode could have an intermittent failure but, after all, this is an espresso machine -
