Help with clogged pressurized portafilter
Postby cookie_monster on Sat Jan 17, 2009 6:00 pm
Hello,
I have a Krups XP4030 ( I know I am an amateur, but that was on clearance and cannot afford anything more expensive) and my filter is clogged.
It is one of those Pressurized Portafilters and I do not know how to unclog it...(it has been decalcified 2 weeks ago, so I do not think this is the problem).
Any advice would be much appreciated.
Thanks,
Iva
cookie_monster
Postby HB on Sat Jan 17, 2009 6:25 pm
Your plight sounds familiar. From Is this filter design "normal":
Michael Salk wrote:Mine has a pressurized basket too. It's the worst idea ever, because it always clogs when the grind is fine enough to produce a proper extraction time - amongst all of the other issues that come with Krups machines or others of their ilk. If you grind the coffee coarse enough to allow it not to jam every other time, the machine produces an entirely blonde 1.25 oz double in 14 seconds. If the grind is fine enough to extract properly, it jams either at the beginning of the shot, or during the next shot, and it takes a minute or two to unclog. The best method is a rather awkward form of CPR, whereby you suck at the bottom hole until the particle of espresso comes loose, and then blow down through the top to force water through. A few thumps with a finger helps too.
I've contemplated trying to buy a non-pressurized basket, but considering the machine won't ever maintain a proper temperature anyway, I doubt it would fix the real problem, which is that the espresso (no matter how good otherwise) is universally sour.
Good luck trying to get yours to work. If you need any advice, email me; I've been fussing with one for months.
Postby cookie_monster on Sat Jan 17, 2009 6:36 pm
Thank you for the reply - I saw that post before and tried it but it did not work for me. I even tried using the valuum cleaner to extract the coffee particles...
cookie_monster
Postby HB on Sat Jan 17, 2009 6:41 pm
Horrible thought, but maybe it's clogged with coffee sludge. If so, soaking it in espresso cleaner (TSP) may help break it up. Sorry I cannot be more specific, I have no my experience with pressurized portafilters.
Postby cookie_monster on Sat Jan 17, 2009 6:45 pm
no...
but I guess without any alternatives I will try that...I will even try boiling it in water first.
Thank you again, I appreciate the fast response.
cookie_monster
Postby sweaner on Sat Jan 17, 2009 9:56 pm
I'm thinking dynamite or C4.
Scott
LMWDP #248
Man does not live by coffee alone...we need beer too.
sweaner
Postby espressoed on Sat Jan 24, 2009 6:50 pm
I think Dan's suggestion that the problem may be coffee sludge is likely to be the answer. Time for some Cleancaf.
I've had the same machine for two years now and have never encountered a problem with grinds clogging the pressurized filter basket. I always run an empty flush shot before pulling a real shot and when finished for the day. If it's not already part of your routine this is something you should do with this machine for two reasons: It clears residual coffee from between the two filter layers that create the pressurization and also helps a bit with getting more consistent temps. There's quite a bit of residual brewed coffee left in there--enough to produce a tea-like color in the flush shot. This stuff is getting cooked into place while the portafilter sits warming in the group head if you're not pulling flush shots.
Since you've already got the machine do what many of us who own it have done and spring for the Krups #0907163 double filter basket, originally made for another Krups unit. It's a standard, unpressurized basket that fits perfectly, though it doesn't hold as much coffee as the original pressurized double basket. Authorized Appliance has the best price for this including shipping. Dan has indicated in the past that the Micro Casa a Leva double basket also fits, though a tight squeeze. Those are currently listed as back ordered at 1st Line Equipment.
It's not the worst machine ever made and will certainly do better than the shots served by countless well-equipped but uncaring shops throughout the land if you keep it clean. Hope this helps.
All the coffee in Ethiopia won't make me a morning person.
espressoed
Return to Espresso Machines
