What should I do!? Change the plug back to a 220V 30A plug? I don't want to blow up my new investment! Thanks everyone in advance, I've learned so much from everyone!
duke-one wrote:Absolutely wrong!!!!!!!!!!!!!
A proper 220 volt circuit has two hots and a GROUND. Don't confuse neutral and ground, you could be in for a big surprise. If you needed a neutral you would need four wires, two hots, neutral and ground.
Duke the Electrician
