Help! Wiring 220V commercial espresso machine at home... - Page 4
Postby Lockman on Tue Jan 27, 2009 12:17 am
Ben Z. wrote:Yes, this is a much better idea than building a box or buying a cord with a 20A fuse in it. I'm not really sure it's all that necessary anyway; does any one worry about plugging a 8A espresso machine into a 15 or 20A outlet?
I think the point was to protect the machine by bringing it down from a 40 amp. Plus I think this machine would pull more than 8 amps. More like 15-20 amps (being commercial) Then if there was a problem the breaker might trip before some major damage was realized. I don't think you would have to worry about the wiring though. Probably wouldn't even get warm...
My reasoning for the sub panel would be so you could run the grinder and or other appliances off the same feed with their own breakers.
LMWDP #226.
"It takes many victims to make a culinary masterpiece"
Lockman
Previous
Return to Espresso Machines
