Help troubleshooting e61 turning on...
Hi,
Ive recently rebuilt an e61 and gotten everything working but its got a slight issue where about 1/2 the time when I turn the machine on nothing will happen. The other half of the time I will hear a faint *click* and the vibe pump will activate and all other functions will work as expected. Sometimes I will need to cycle the power switch to get it to function.
I assume the *click* is a solenoid?
Where do I start looking to troubleshoot this intermittent issue?
Thanks
Thanks
- Randy G.
Next time it happens, use a voltmeter to see if power FROM the main switch is getting out of the switch.
- homeburrero
I'm not sure which ECM you have, but I'm guessing it has a light that indicates power on. If so, that light should tell you whether or not the switch is working.Randy G. wrote:Next time it happens, use a voltmeter to see if power FROM the main switch is getting out of the switch.
Many of these (especially the old ECM Giotto classics) have intermittent problems with the reservoir sensor. If the reservoir sensor does not detect water, the controller shuts everything off (pump, auto-fill solenoid, and heater.) The faint clicking may well be the relay in the controller responding to that reservoir sensor's intermittent sense.
Let us know more precisely which ECM E-61 you have and that might help with more specific suggestions.
Pat
- erics
- Supporter ★
Better yet, take some x-rated pics of the internals, specifically the control box and the wiring diagram on it.Let us know more precisely which ECM E-61 you have and that might help with more specific suggestions.
Do a site search on "ECM Giotto" and then further narrow that down using the term "Gicar".
Thanks for the feedback so far guys
This is a La Scala butterfly.
The light lights up when the power is turned on in both working/non working states.
I will get some pics tonight
Dying relay in the brain box. You can get a replacement box here, http://www.espressoxxl.de/shop/artikel/ ... etail.html .
Alan
Alan
