HELP!! Rancilio Silvia and Vario grinder
I'm a newbie but a latte and coffee lover .....
I just got a Vario grinder and Ive had my Silvia for awhile now. I LOVE my Silvia! So I grinded my own coffee for the first time ever today right into the portafilter. Then I inserted the portafilter and told Silvia to throw me some shots and.... nothing came out. No coffee poured in my cup at all. The Rancilio Silvia just made a bunch of noise. The machine was on, warmed up, has water in it, and all good to go..... So does anyone know what I did wrong. I tamped as usual, all the same techniques as always but the only difference is I grinded my own coffee. I don't know at all what settings to use for the Vario yet I just planned on experimenting to find out. Any tips or pointers for the pair would also be awesome! Thank you everyone
Oh and... I tested the portafilter with no coffee in it and water comes threw like normal so I know Silvia is not broken... Thanks everyone.
The coffee was ground too fine. Try a slightly coarser grind setting.Aras6 wrote:So does anyone know what I did wrong.
Jim
Really?! Hahahaha! That's all? Well good then thank you Jim I figured it would be some crazy thing that involved tools or water pressure settings. I was not looking forward to that. Ha!
Your grind is too fine and/or you tamped too much (grind size and tamping pressure can be combined in a variety of ways to produce a puck that presents a certain amount of resistance to the water flowing thru).
So you now have a puck which can resist more than 9 bars of pressure, and there's a valve in your Silvia that open at 9 bar and shunts water back to the tank. the OPV valve, as it's called, it's there to ensure an optimal extraction profile at 9 bars.
Result: the pump pumps water, the puck behaves like a blind filter, and all the pumped water goes back to the tank.
Grind coarser, and/or tamp with less force, until you find that perfect combination of grind size and tamping pressure to achieve 25 ml flow in 25 seconds or so
Okay! Thank you Robca! Thanks for explaining how it works too I guess I've been lifting too many weights lately tamping too hard. (I know.. I'm corney) Ha!
Okay I'll try not tamping too much and a more coarse grind. Thank you
