Re: scale, possible blockage etc: I previously had cleaned all components by liberal bathing in citric acid solution and have blown out all the tubes with compressed air to assure they pass air/water, so I doubt scale buildup is the cause.
Re: Steam & Hot water valves not functioning: I previously had disassembled them and cleaned in citric acid solution as well. Then reassembled. Today, after reading your post, I once again disassembled them and blew compressed air through the steam valve assembly. I could not get air to flow through the hot water outlet! Both looked clean, but frankly I am not sure, after looking at exploded parts diagram from two different parts suppliers, if the hot water valve is, or ever was assembled correctly.
At any rate, I have no steam or hot water.
Re: Vacuum breaker on top of sight glass: I will order replacement.
Re: the pressure gauges: I disconnected the capillary tubes tonight and blew compressed air through them both. I also put compressed air to the top inlet and got the needle to register approx 1 bar. The lower needle registered nothing when I applied compressed air....I don't know if there is a way to clean out the gauge or not.
So water flows through the HX, but before you do any more serious work you should verify the integrity of the HX... if it is cracked, GAME OVER. You can see if the boiler holds pressure and does not lose pressure to the HX or vice versa.
This sounds gosh-awful serious. How do I verify the integrity of the HX to determine if it is cracked?
Is the following a true statement? The water for the steam valve (frother) comes from the HX? The water for the hot water tap comes from the HX?
Frankly I cannot tell on the surface of the boiler which fittings emanate from the boiler and which from the HX. I can tell you that the two lines feeding the aforementioned steam/hot water valves were cooler than the two which feed the Group Head when I had hot water in the boiler.
Re: three way valve: I do believe it is just a fitting as you noted and NOT a valve....BUT it does feed the steam valve.
I apologize for my lack of familiarity with all the component names.....
Thanks for your assist. Any further input is appreciated.
In conclusion: I have come to the point where I think I need to take the whole system (Machine, pump/water softener) to William at Home Espresso Repair in Seattle. he's only about a 30 minute drive for me. I hope he can fix the final issues I have been describing.
