Steve -
You want to change the expansion valve seat because the valve is screeeeeching !!!!!
OK - see the Chris' Coffee FAQ re removing Andreja's casing -
http://www.chriscoffee.com/faq Unplug machine and let her cool down, then remove casing.
You should have on hand a replacement o-ring for the pressure adjusting nut and a small quantity of Dow-Corning 111 Lube - available here (and maybe elsewhere) -
http://espressocare.com/Qstore/Qs...ME=Dow+Corning+111
Detach the silicone hose which is a force fit on the adjusting screw outlet.
Unscrew adjusting nut - typically the pressure adjusting nut is screwed ABOUT half-way in so have a paper cup to catch the water that escapes when the plug "escapes" from the housing. Out will come the nut, spring, & valve.
Insert your little finger into the valve housing to feel for any scale buildup. If any is present, the valve body should be removed and soaked in white vinegar for about 30-45 minutes and rinsed/cleaned with a toothbrush.
Remove the old o-ring and lubricate both the groove for the o-ring and the new o-ring itself with about a matchhead's worth of lubricant. Use another matchhead's worth on the first inch or so of the valve body where the o-ring will rest.
Assemble the now "good as new" expansion valve, screwing in the adjusting nut ABOUT halfway. Apply some thread sealant to the male threads if you removed the expansion valve body. Be a little cautious when screwing the valve body back in - just snug is good.
Run Andreja (cold is fine) with a blind filter basket and adjust the valve till the brew gage reads 9.0 bar.
