Help identifying Angeli Inox espresso machine type
Postby spiffdude on Sun Feb 06, 2011 9:53 pm
Hello,
Since i now have my new Rocket Evoluzione set up, i was cleaning my old machine to put it in storage as a backup.
While i was cleaning it, i figured i'd open it up to have a look at the internals. I was surprised by the cheapness of the actual hardware. I got this machine from my brother in law a long time ago (gave it to me, bless his heart) but i know it still currently sells for about 375$ canadian at Faema in Montreal.
I can see the vibe pump that's mounted on two rubber straps and this pump feeds that big brass round thing (it's brass since the descaler comes out green). I assume that cannot be a boiler, it's size tells me it could not hold more than 1 cup of water. The brew head is right under it. It does feed both the wand and the brew head...
I always thought this was a single boiler dual purpose unit. Am i mistaken? Is it a thermoblock or something else?
Damn this forum, I've had too m..muh...mah..mmmm..much caffeine!
spiffdude
Postby HB on Sun Feb 06, 2011 10:11 pm
spiffdude wrote:I always thought this was a single boiler dual purpose unit.
Correct; the two button type thermostats are clearly visible (blue), one for the brew temperature, the other for steam temperature.
Postby cannonfodder on Sun Feb 06, 2011 10:59 pm
The rubber straps holding the pump are relatively common. The rubber mounts isolate the pump vibration from the frame to reduce noise.
cannonfodder
Postby Alan Frew on Sun Feb 06, 2011 11:36 pm
It's the equivalent of an early Nemox Fenice or Imat Junior. 270mm brass boiler, presumably 57mm portafilter (but may be 53mm), thermal fuse instead of resettable thermostat. The interesting thing is the lack of an OPV, you wouldn't want to choke the flow too often.
I'd look at replacing the "steam" switch too, note the discoloration of the connector.
Alan
Alan Frew
Postby spiffdude on Mon Feb 07, 2011 11:07 pm
Thanks for the feedback, i didn't realize boilers could be that small. It's got a 53mm group by the way.
I may get new connectors for it, the ones on there are quite dried out and fragile.
cheers
spiffdude
Return to Espresso Machines
