CyclingCraig wrote:How often do you check your boiler water and what do you use to check it? I am using one of those aquarium test kits with the droppers and test tubes?
Hi, Craig, hope you are enjoying your Anita. Others here are more qualified to answer, but here goes. Right now, I'm checking it weekly, just to get a handle on the water's properties. I hear the droppers are more reliable, but I have been getting by OK with the test strips. Apparently, you can also get electronic Total Dissolved Solids testers for c. $15.00, but I am not familiar with conversion to relevant hardness from TDS.
CyclingCraig wrote:I was doing the same process as you, Let the machine come up to pressure, turn power off then open the hot water wand until no more water comes out. But I assume that is not ALL the water in the boiler? How do you get the rest of the water out, or do you just wait a little while for things to cool down, Turn machine back on and let the boiler refill and then repeat the process to slowly replace boiler water?
Right. I think most of the water comes out and I've not worried about the rest. I just make a point of refreshing the boiler regularly. To check it, I pull water from the Anita's tap then let it come to room temperature. It's been instructive to compare its hardness level to the water going in. Water in the boiler has been significantly higher, from the steaming.
CyclingCraig wrote:Last time (Yesterday) I check by water hardness it was about 35 PPM or 2 grains. I assume anything under 3 grains you are pretty safe from scale?
That's the party line from Chris's, 40 ppm or less. But that's your reading for the water going into the tank or from the boiler's tap? Definitely need to keep an eye on what's in the boiler by checking the tap. By the way, keep in mind the instructions from Chris about filling the boiler: run the pump for no more than 30 seconds at a time, then power off for 5 minutes. This is to avoid overheating a possibly exposed boiler element.
Best, Brad
