BradleyB wrote:Not sure how its life-cycle works. Is this softener unit rechargeable, or is it replaced at $17.95 a pop on a regular basis?
Thanks,
Brad
The Softener is rechargeable with Kosher salt and has to be done about once a week or once every 2 weeks, depending on water in and usage.
To recharge you basically remove your tank, fill tank with fresh water and add 3 tablespoons salt to it... Mix it up good. Then using a dedicated rubber tube for this, syphon the salt water from the tank thru the filter into the sink. once that is done, fill again with FRESH water and syphon again to clean out salt water from filter and you are ready to go again.
It's a little bit of work, but worth it for the extra protection I hope for my boiler?
-Craig
