KSinning wrote:No "on" light when the switch is in position I, and no pump/autofill, the only light is the water safety light.
WARNING: ALL power for the machine passes through that switch (which I never liked- it should have been through a relay). DISCONNECT the power cord before doing the following tests:
It sounds like there is a problem with the water level safety switch under the reservoir. Lift and then push down on the reservoir repeatedly.
Do you hear a "Click with each lift and release?
If YES then access the switch. You will find three wires connected to the switch. If you remove and jumper the two black wires (connect them electrically together) and the machine now works, you need to replace the switch and all will be well.
If NO CLICK, then there is a problem with either the switch or the adjustment of the actuator level or screw.
