HB wrote:A bike pump? I would like to see a video of that in use.
Somewhat far-fetched but not completely out of the realm of possibility.
My road bike tires are typically inflated to around 110-115 psi, which equates to around 8 bar. I'm sure there are some even higher performance bike tires that get inflated to an even higher psi level.
Larger, floor standing bike tire pumps have no difficulty reaching 8 bar, and I'm sure they could easily reach 9 bar as well. The small emergency bike pumps that one finds attached to bicycles on a tube have difficulty getting much above 60 or 70 psi in my own experience; enough to maybe get back home after changing a tire in the field, but not the usual inflation level for a road bike tire. Fatter tires (e.g. mountain bike or crossover) generally have lower psi inflation levels.
Since this product is being touted as something you could take along on a hiking trip, I think it is most unlikely that the sort of small pump one might carry in a backpack would be powerful enough to get real pump extraction pressures like one sees on a pump driven espresso machine.
And all of this assumes that there is some sort of air tank in the device that can store the pressurized air, because trying to use a bike pump to make an espresso at the moment when one is pumping seems beyond ridiculous to me.
ken
