Thanks for the quick reply Eric-
The whole machine is shut down.. no pump, no heat- just RL3 opening/closing every two seconds or so...
Not sure what you're looking for but I attached a few pics below...
LMK if there is something you want to see closer up....
Other than replacing the safety valve, vacuum valve and pstat (replaced with Jager),
The only mod on this machine is the conversion from the original tank that had the supply and return tubes hanging into it, to the drop in tank with the plastic coupling.
Everything else is original...
Tried tilting the machine towards the probe but didn't do anything - now wondering, if the level probe is open (I'm guessing that would signal empty by floating the voltage), wouldn't that trigger the pump to fill the boiler? And if it's signaling that it's not empty/low (i'm guessing it would close to ground when it contacts the water), wouldn't that allow the heater to run?
The heater resistance is 8 Ohms-
- I've always used water filtered with active carbon- no scale problems....
the machine was completely descaled a few months ago (although didn't really need it).. at the time, I pulled the heater back then and checked the tank with a flash light... clean as a whistle....
I could really use a run down of what voltages I should expect to see on each of the pins of the Gicar on a cold machine...
The loose green/yellow wire along the back is the chassis ground from the original tank set up....
Back
Pump Side
Back from top
controller side
