by SNielsen on Tue Apr 07, 2009 5:12 pm
My four-year-old Giotto is making some very curious noises when it first gets switched on in the morning. You can hear what sounds like a solenoid clicking away continuously inside the machine. Frequency is about once every second. This lasts for approximately 2 to 3 minutes, then the frequency slows down and then it stops altogether. During the clicking, the pump to fill the boiler sometimes kicks in and out to the rhythm of the clicking, but sometimes it runs for 10 seconds continuously (no clicking while it's running). This tells me that this solenoid (or whatever it is) has some control over the pump. Once it stops, the machine proceeds to heat up normally, to normal pressure, and brew and steam as normal.
FYI, I can't hear the boiler heating while the clicking is going on, and it only seems to start heating when the episode stops. Also, there's no clicking whatsoever when hot, and no pump cutting out when hot. So this only happens for the first few minutes at start from a cold state. BTW, the machine gets descaled about every four months, if that's relevant.
So, before I open up the machine to look at the guts of it, does anyone have any hints or ideas as to where I can start looking? Corroded electrical connectors, perhaps? A sensor of some kind that's shot? Or perhaps I'm fooled by the sound into thinking it's a solenoid, when in fact it's the pump itself? Any help greatly appreciated!
Cheers....
