Your starting point sounds reasonable.
I believe that comparing brew pressures in sub-1.0 bar increments is not meaningful since that falls below the accuracy of the built-in gauge. Even if you compared with others using a Scace II thermofilter, I would still recommend the hands-on approach: Increase/decrease the brew pressure at least 1.5 bar and compare the taste (take notes). Based on your results, halve the difference between your previous setting and the current setting. Repeat until convinced the results are unchanged.
My bet is that within a dozen extractions, you'll end up where you are today ±0.5 bar.
