You have to drill a very large hole with a Forstner bit for the bolt end, then a brad point for the back end of the tapered shaft. Then take it off the vice, turn it around, get it perfectly centered on the drill press on the other end of the stock and drill the larger hole for the thick end of the tapered shaft. Since the shaft is a fixed size, you have to set your press depth settings for all 3 drillings so each section is the correct length. If it is not perfectly aligned in the vice for the drill press your holes will be off center and you have to start over. Once they are drilled you have to chisel the square for both ends of the portafilter's dog stops to fit into. Then you can chuck it and turn it in the lathe. I turned a press fit end cap to close the big hole up in the end of the portafilter and turned a matched tamp handle out of bloodwood.
Major pain. The next one wont be $35, more like $80 because of all the work involved. Or you could get the drill press, drill bits, lathe, tools and turn one. It only took $1800 in tools to make it. Seriously, it took all evening to figure out how to make it. That taper is the killer.
