by JeremyNelson on Thu Jul 24, 2008 11:59 am
Hi Vince! (this isn't vince from Wpg is it?)
I've just got a Gaggia Baby Class + Isomatic Pro grinder (special from creativecookware.com) and have been very happy with it. I'm trying to post a review on coffee geek but the site is down (check back later this week). But long story short, within 24 hours of getting the thing, I was making easy-to-replicate great shots. The steamer wand leaves a bit to be desired (not really in terms of heat, just in terms of frothing). Otherwise, been very happy....hoping though that the buttons hold up a bit better than those on regular baby, which I've heard some have had problems with. Anyway, seeing as its similar guts, if you get a baby, here's my tips:
1. Grind real fine while stirring with toothpick or similar (PF should be level with coffee before tamping).
2. Tamp NSEW and then centre -- about 30lbs pressure (use a bathroom scale till muscle memory builds up)
3. Brief flush, brief waiting period then pull shot
Really basic, but even with the cheap "cat-toy" tamper, it was producing shots that didn't require any sugar but were still pretty rich...better than most places in Toronto, that's forsure! I'm going to experiment with an even finer grind and lighter tamp (like the Italians do it) to see if I can improve the intensity of the shot. Start-dumping about 1 second of flow helps too with consistency (you loose a bit of the intensity, but I'm doing it when I make it for others who may not like that tiny bit of bitterness the way I like it).
Cheers -- and do check out creativecooking.com -- my order arrived 24hours after it was placed, well packed, with cups, a small frothing jug and a bit of joe, and what's more, because they are Quebec based, you save the PST. Not bad!
Cheers,
Jeremy
