Gaggia Classic + MDF problem with soggy, soupy puck from portafilter.
Hi,
I am new to this forum and have been reading up information on here for a few weeks. Very informative stuff here. thank you! Recently, I got a Gaggia Classic and a Gaggia MDF grinder. I have been practicing trying to get good shots. Before, the MDF arrived, I had practiced some with Illy pre-ground in a can (I know folks will cringe at this ) I was actually getting fairly decent shots with a good tamp. 20 sec. or so shots and nice solid puck. Once I got the MDF I have been having problems with a really soggy, soupy puck that falls apart when removed from the porta filter. I am using LaColombe Nizza beans which as far as I can tell from the date are pretty fresh. I grind with the MDF at setting 6 nearly choked my machine. I moved to a setting 7 which produced a decent 2.5 oz shot, in around 25 sec which to me seemed like it should be ok. However the shot tasted a bit burnt and the puck was soggy and soupy looking, not solid.
My inclination here is that the grind may be too fine still, causing this to happen? or tamping to hard? Does anyone have any advice for me? I go to setting 8 and the puck is still not very dry and formed either.
Thanks alot,
Tim
Thanks alot,
Tim
Welcome!
Have you checked out:
Espresso 101: How to Adjust Dose and Grind Setting by Taste
Are you using freshly roasted beans? When you say burnt do you mean bitter or harsh? If you experiment using the great information from above you will be able to better target what you can do to improve the taste. The appearance of the puck is less important when figuring out how to dial in your shots.
Best of luck and enjoy!
- another_jim
The espresso tastes the same whether the pouck is soggy or not; so why are soggy pucks a problem?
In actual fact, pucks are soggy if you use low doses; which is often a good idea. They firm up if you use higher doses; which is often a bad idea.
Jim Schulman
Until/unless WLL stops pushing the Classic/MDF combination, poor results will continue plague the owners of new Gaggia Classics. The MDF is an inadequate grinder, and WLL should know better.
Thanks for all the helpful responses. I will continue to practice and good to know the soggy puck is not a big deal. I would say the shot was a bit burnt rather than sour. I will alter my tamp a bit as well see if that helps the taste. I would say i had a quarter of an inch of nice looking crema though. Seemed nice looking. BTW. Is there any ideal crema thickness? Or relative to ones preference and taste?
Thanks!
Tim
Thanks!
Tim
There are some really good videos of shot extractions that you can find by searching that will show you what good shots look like during extraction. But again, like with wet pucks appearances can be deceiving. Focus on the basics and the resulting tastes.
Best of luck!
Best of luck!
