I can make water or steam normally via the steam wand.
So far:
* Ensured the steam switch wasn't enabled
* Ensured the intake hose(s) aren't blocked or stuck to the sides of the water tank
* I've plugged it into a GFI - no apparent short
* Cleaned the screen
* Descaled the machine
I'm getting a metric hex wrench to unscrew and clean the group head to ensure there's no blockage there. I'll also try to get a better read on the water temp coming out once it actually stops steaming.
Any other ideas? I'm not up to cracking it open since it's still under warranty, though sending it to NY for warranty work sounds awful, mostly because we'll be without a machine for 4-6 weeks (I'm guessing) once shipping time is included!
I'm fearing some major blockage inside, or a crack, or, perhaps most likely, a bad brew thermostat?
