I bought a used Gaggia Carezza Silver Serial #0106047710 and it will not prime its pump. When I first unpacked it, I heard something moving around inside? I removed the top and one of the plastic pieces that holds the pump to the unit was broken. The pump was dislodged from where it should be. I got the left side of the pump mounted correctly where it should go, and this seems to be enough to keep the pump in its place.
I noticed on another forum, someone said I would have to "reset" the pump if it became dislodged? I also saw where someone suggested that I remove and clean a part that is screwed into to the lower end of the valve that controls the steam flow when comes out of the steam wand. This is done using a black knob that is screwed into the top of the machine. This valve I mention is connected to the top of the boiler with two connections going into it. Then screwed into the lower hole 'the part that needs cleaning' is mounted there with a hose connected to it which comes from the pump.
Before I take it all apart someone please advise me what to do. I went through the priming procedure correctly. It will not suck up any water when I turned on the pump and opened up the steam valve, nor would it build up any steam when I turned on just the steam switch. After awhile some drops of water did drip out of the steam wand, but only three or four.
The pumps makes allot of noise, and the top of the machine feels hot. I did turn it off after a minute or so to avoid damage. I went through the cleaning procedure, removing the screen held by a screw and the metal part held by two 5 mm Allen screws. There was allot of deposits and the people I bought it from messaged me later that its been sitting up for two years.
I think something is just badly clogged. The inside of the machine was wet also.
Help,
Mark
