by David R. on Mon Sep 12, 2011 5:41 am
Doesn't really matter. On my Gaggias whenever I replaced this valve I only replaced the pea and spring, not the valve housing.
You probably need a new valve. Try removing the pea/spring, stretch the spring by hand a bit, reassemble, and see if the coffee is any better. If so, order a replacement (the 'stretch' fix is not permanent).
David R.
