My thinking is put them inline right before the group head and have the FPR dialed into pre-infusion pressure. Then using a separate hydraulic air lever that delivers a set psi (in air) you can ramp up the pressure simply based on the location of the lever as most FPRs ramp up on a 1:1 scale. (The other option is simply use the steam pressure from the boiler and an FPR with a rising rate scale of 1:5 let say so u can use a valve but perhaps less control and variability is introduced).
1) set FPR to lets say 50 psi
2) have air lever produce 80 psi max
3) start shot at 50psi, pull lever and hold adding 80psi to total 130 then slowly back off manually ala slayer action
Yes no?
Here is how these things work, you can get them with a return or without, on an HX a return would probably be required as temps would rise if the water is static, return could enter the boiler although that could introduce new problems:
-engine vacuum in diagram is actually +pressure from the intake manifold and it is where the controlling pressure is derived from
