1. Electrical hook-up and pump mount
2. Flanges, end
3. Bolts and lock nuts, assembly
4. Fitting, inlet
5. Fitting, outlet
6. Coil, electrical
7. Spring and flange, piston
8. Piston
9. Gaskets, inlet and outlet fitting
10. Flange, outlet gasket
11. Spring, outlet one-way
12. Balls, glass one-way
13. Spring, inlet one-way
14. Seal, piston
Visible is electrical hook-up (1), end flanges (2), assembly bolts and lock nuts (3), inlet fitting (4), outlet fitting (5), and electrical coil (6)
with electrical hook-up (1) removed. "prod 15/89" is believed to mean produced in the 15th week of 1989.
With end flanges (2) and assembly bolts and lock nuts (3) removed, removing outlet fitting (5) to reveal one glass one-way ball (12), the tip of the piston (8) and outlet gasket flange (10) and one fitting gasket (9)
Interior of outlet fitting (5), reveals outlet one-way spring (11)
Outlet with outlet fitting (5) removed
Removing outlet gasket flange (10)
Removing piston (8) and seal (14)
Removing inlet fitting to reveal one glass one-way ball (12) sitting on inlet one-way spring (13) (not visible) inside of flange of piston spring (7). Also one fitting gasket (9)
Inlet one-way spring (13) is visible
Removing piston spring and flange (7)
Piston spring and flange (7) with inlet one-way spring (13) and one glass one-way ball (12)
Inlet fitting gasket (9) removed
Electrical coil (6) with all parts removed
It has been several months since these photos were taken but I will do my best to answer any questions, comments, or curiosities. For reassembly simply work in reverse.
