Flood Mitigation for Plumbed Espresso Machines
Link to "Flood Mitigation for Plumbed Espresso Machines"by 703Eric on Tue Jul 22, 2008 12:30 am
Hi Everyone, I had posted a question in January asking if anyone had any ideas on flood mitigation. I only received one answer which made me start to feel like I was being paranoid but I figured better safe than sorry so I wanted to share my solution.
I was able to find a really great kit at DIYCONTROLS.COM that only set me back $158.00. The kit consists of a brain box that has battery back-up, 3/8" motorized shut-off valve, two water sensors, x10 controller and a 220v receiver box for the x10. The water sensors can be strung together to add as many as you like. When water touches one of the sensors it completes a circuit and the brain sounds an alarm. It than shuts the motorized ball valve killing the water supply and triggers the x10 to send a wireless signal to the appliance power box that kills the power. All of this happens in less than 3 seconds and completely exceeded my expectations. The wife was super cool about me adding an espresso bar during our kitchen remodel but I knew that if we ever came home to a flood the Linea would go Bye Bye. Thanks to everyone for all of the great information over the past year!
The Guts
The Brain Box and X10 unit which sends the signal to kill the power
What luck for rulers that men do not think. A Hitler
703Eric
Link to "Flood Mitigation for Plumbed Espresso Machines"by 703Eric on Tue Jul 22, 2008 12:34 am
The inline motorized ball valve
The unit that receives the signal from the X10 and kills the power Image
One water sensor next to the pump
703Eric
Link to "Flood Mitigation for Plumbed Espresso Machines"by 703Eric on Tue Jul 22, 2008 12:37 am
The last water sensor under the espresso machine
703Eric
Link to "Flood Mitigation for Plumbed Espresso Machines"by shadowfax on Tue Jul 22, 2008 2:28 am
That's a fantastic job! I really appreciate you bringing this to our attention.
Those of us with plumbed in home machines (e.g. Vetrano & La Spaziale Vivaldi) would be wise to consider something like this for the freak accident type occurrences: even if you are cheap, about $90 gets you this:
FloodStop 3/8-C
That's the unit with just the sensor and the ball valve that connects to the water line. You can put this just ahead of the Max Adaptor that Chris' Coffee sells to plumb in machines using John Guest fittings. Note it will also shut off your sink (or whatever you tapped into) water supply, but that's not really a bad thing.
The FloodStop unit seems easily justifiable: flood damage will destroy your espresso machine and can cause 10s of thousands of dollars of damage to your house. The machine shutoff is maybe harder to justify: as long as the water is shut off, the worst that could realistically happen (you would think) is your heating element could burn itself out, if the emergency thermostat doesn't shut it off. These heating elements usually cost about the same as the 120V appliance controller that they sell, so it's maybe a gamble there. I think I would get it, myself, as changing a heating element is not overly pleasant...
Eric, thanks again. I am moving in a week and buying a special counter with sink from IKEA for the espresso setup, all plumbed in. I was thinking of getting a flojet for the security (not having to worry about more than 5 gallons getting pumped into the kitchen), but this is a great alternative at a similar price.
Nicholas Lundgaard
shadowfax
Link to "Flood Mitigation for Plumbed Espresso Machines"by Spresso_Bean on Tue Jul 22, 2008 12:06 pm
That is a nice system you installed. I have a basic 1/4 turn ball valve where my water line hookup is, and I just turn it to allow water flow before turning the machine on, and then off when I'm done. That should limit any potential issues I believe, and it barely takes any effort to turn on/off.
LMWDP #200
Spresso_Bean
Link to "Flood Mitigation for Plumbed Espresso Machines"by 703Eric on Tue Jul 22, 2008 12:23 pm
Hi Spresso Bean, That is by far the most simple solution but the warm up time on a LM is hours. I also didn't want to constantly turn it on and off as this creates metal fatigue. I would also imagine that the constant heating and cooling would cause any scale to build up much more quickly.
703Eric
Link to "Flood Mitigation for Plumbed Espresso Machines"by Spresso_Bean on Tue Jul 22, 2008 1:04 pm
Oh yeah, yours is much more sophisticated than what I did, but I was more describing what I did for a machine that usually only requires about an hour to heat up. For something such as a Marzocco I think what you did is perfect and seems to cover just about anything that could go wrong with having a pressurized water line connected to your machine. Having a flood would be awful.
LMWDP #200
Spresso_Bean
Link to "Flood Mitigation for Plumbed Espresso Machines"by jesawdy on Tue Jul 22, 2008 1:21 pm
Thanks for the information... this is a great setup and certainly worth every penny. I need to look into the kit options and parts a bit more, but I'm curious if you considered (and discarded) the notion of a direct relay (vs X10 wireless) to control the cutoff of the power?
Jeff Sawdy
jesawdy
Link to "Flood Mitigation for Plumbed Espresso Machines"by 703Eric on Tue Jul 22, 2008 2:41 pm
Hi Jeff, to tell you the truth I would have preferred a hard wire set up over the wireless X10 unit but I couldn't find anything that would work. If you do find a wired system for the power I would love information on it.
Thanks
Eric
703Eric
Link to "Flood Mitigation for Plumbed Espresso Machines"by Paul_Pratt on Tue Jul 22, 2008 8:19 pm
Very neat system. At home I have something along those lines - I think I noticed Dan's set up has something similiar. I have a 1/4" solenoid valve mounted via a fitting to the inlet of the procon pump. The pump and motor are heavy enough to support this. The solenoid is then wired parallel to the pump wiring.
So when the machine needs water it turns the pump on and at the same time opens the solenoid. In 4 years no problems with pump, solenoid or water leaks.
Paul
Paul_Pratt
Link to "Flood Mitigation for Plumbed Espresso Machines"by 703Eric on Tue Jul 22, 2008 8:36 pm
Hi Paul, Thanks for chiming in. On another note, THANK YOU, THANK YOU, THANK YOU for your kick arse article on installing the old cage and bolt style LM group heads. I was able to get mine done in 30 mins. flat. Without your step by step article I think it would have taken days! YOU'RE THE MAN! :wink:
703Eric
Link to "Flood Mitigation for Plumbed Espresso Machines"by Ken Fox on Mon Dec 08, 2008 2:25 am
I was about to make a new post about home wannabee espresso plumbers and the risk of water damage, but I see with the search function that the subject has been raised once before (here).
Having recently remodeled my kitchen and now having 2 complete plumbed in espresso setups, my paranoia has gotten the better of me and I decided to invest in some cheap water alarms from Home Depot. My own plumb in jobs were primarily done by a (real) plumber so they are probably more substantial than what most home users have, however the last portions are composed of John Guest tubing and fittings which I put together myself.
Although it might be appealing to try to put together a "fail safe" sort of system that interrupts the flow of water if there is a leak, I think that a much simpler solution exists for about $10 from your local Home Depot or Lowes. The model that these stores sell is called the "Watchdog" water alarm and is basically a transistor radio sized white plastic thing that takes a 9v battery and which will produce a very loud alarm if there is even a very small amount of water pooling up under the sink (or anywhere, for that matter). There are at least several other similar alarms produced by other manufacturers which are sold through other stores and I have no reason to doubt that they work equally well.
For those amateur plumbers among us with plumbed in espresso machines, I think that a very modest expenditure on a water alarm such as this would be money well spent in the unlikely event that something under the sink starts to leak . . . . .
ken
What, me worry?
Alfred E. Neuman, 1955
Ken Fox
Return to Espresso Machines
