I'm planning on fitting a T-piece just after the pump and piping this to the pressure gauge. My question is, does anyone know what the fitting size is just after the pump? (Circled on the photo.)
Thanks!
erics wrote:It is difficult because of the close quarters you are working in and the various fittings can become a nightmare. See here and look at the pictures in the folder "silvia undressed":
http://users.rcn.com/erics/
The easiest place to temporarily read the brew pressure (while brewing) is where the steam line attaches to the boiler. The fitting on the boiler is 1/4-19 BSPP and a normal US pipe thread fitting is 1/4-18. With a little teflon tape on the boiler's threads and the use of brass fittings, it will seal.
If you wanted to do something more permanent, Chris Coffee sells a pressure gage cap tube setup:
http://www.chriscoffee.com/produc...arts/capillarytube
I believe these have 1/8-28 BSPP threads vice the US standard of 1/8-27 and you would need to tee into the steam line and adapt from there. Going between the boiler and OPV, you are faced with the prospect of undoing those fittings where the teflon line connects and reassembly can be iffy depending on machine age and other factors. In addition, there is not enough play in the teflon line to do what you want.
The most non-intrusive & easy solution is the PF gage and, if you build one, use a liquid filled gage.
Eric S.
erics wrote:The only item to be a little cautious about re Gabe's fine work is this:
The connection between his pump and OPV is/was M6x4 teflon tubing which is easily trimmed with a tubing cutter or carefully with a razor blade. Your connection is SS braided tubing at a fixed length so you really need to put a tee at the pump to keep the length the same or make some other modifications depending on tee placement. The glycerin filled gage you have does not require any small, coiled tubing as a "normal" pressure gage would.
