by dizzillusionist on Tue Oct 13, 2009 11:05 pm
Thanks, paperpig. I more or less modified my Silvia for a pressure gauge like you did. I did find a source of supplies that made things both easier, and less expensive:http://shop.hoseandfittings.com/catalog/Fitting/Brass/Push_to_Connect.html I elected to use their push to connect and so far am using the Nylon pressure pipe, since none of this is in the hot zone. Item 50210 for example allow you to cut about 2 cm of the teflon pipe (mine does not have the metal jacket) and simply slides in, and gave me 1/4" NPT for an output. Then there are pushconnects so that a connector can be screwed onto the gauge and you then simply slide the hose in.
SO-here's my problem that needs a troubleshoot. I did this because my PID'd silvia has been making me unhappy. I find that when I turn on the hot water, the pressure climbs up to 10 bar. But if I fire up the coffee valve, the same gauge shows no pressure. The pump is running either way. I certainly get water under pressure out of the group head. This can't be the OPV, and the pump is running. WHAT don't I understand?
