First time here, my name is Antonio and I have bought a second hand Fiorenzato Ducale for my business. The machine was supposed to be "serviced" but it has already broken twice (heating element and one solenoid) and I have some questions about the setup.
I have wrtitten a couple of threads on the coffegeek forums, but I haven't got any reply, maybe just one. I understand that cross-posting is not good but I hope I have waited enough time for me to post on another forum.
I am a technical guy and I have always been fashinated by coffee machines. Now that I have a professional one I'd like to get the most of it!
The main issue is with water I guess. I have a cilindrical softener (the one with resins that can be regenerated with salt) and the water coming from the softener is not very good actually. I tastes like "pipes", "burnt rubber" but tap water is not so bad, I would say "average".
As a consequence the water coming out of the machine smells funny but the coffee is very good.
I cannot use the water for a tea, the water is full of limescale and with a funny taste. This leads me to believe that either the softener does not work anymore or the boiler is filthy with limescale.
So following a suggestion from coffeegeek I emptied the softener canister in a clean bucket and puored into it 1.5Kg of salt. The canister looked good, I tried to remove any residual smells with some soda bicarbonate and vinegar. I rinsed the canister thouroughly at the end of course.
I left the resins alone with salt for a couple of hours, mixing them and replacing a bit of water every now and then. The water level left a "dark" dirty border on the bucket and that leads me to believe that the resins are not in good shape either
The procedure didn't have any effect unfortunately so I have ordered new resins. I do believe that if water is smelly, it's pretty useless to look into anything else, do you agree?
Second issue: water pressure. Trying to squeeze the most from my machine I set the water pressure to 9atm, I understand that this is what it is supposed to be. The pressure meter was reading 8atm and the needle was pretty steady. When I set the pressure to 9atm, the needle started to oscillate between 8 and 10. Is that ok?
I then set the grinder for a shot of 25ml in 25s. The coffee had a nice cream on it, but with a "white button" on top, and I do understand that this should mean too high temperature or grinder to be adjusted. But since I have the shot in 25s, I was thinking of the temperature. Any way to adjust it? I measured the temperature out of the machine with no filter and it starts at 97 degrees when it's still boiling to drop to 80 degrees approx after 20s. I read somewhere that the water temperature should be 60 degrees?? looks a bit low to me.
Finally I was told by my partner that now the shot takes 45s and if he adjusts the grinder a step then it takes only a few seconds. Need to investigate but if you could give me some hints I would really appreciate it!
Thanks a lot
Tony
