www.ajcoffeeco.com: excellent coffee without compromise
Fiorenzato Bricoletta problem.
Postby JitterBug on Sat Sep 24, 2011 5:54 pm
Hello,id appreciate any help with this issue.I had this machine for a while,used very often.Now all of a sudden it does not work at all.I flip the toggle switch,red light goes on and thats it.It does not heat or build pressure.
Thank you
* * * * this space is reserved to remind everyone to support their local animal shelter * * * *
JitterBug
Postby allon on Sat Sep 24, 2011 9:50 pm
If you have any electrical skills, or know anyone who does, you can trace the circuit; typically, power will turn on the pilot light (so you know it has power), and feed the heating element via the pressurestat, which interrupts the circuit when up to pressure. There is also an overtemperature cut-off in case the pressurestat fails closed (which would also lead to venting pressure).
If I had a multimeter and was comfortable working with 120VAC, I would first check to see if there was voltage at the heating element. If yes, then the heating elment is suspect.
If no, then check for voltage at the input of the thermal-cut-out. If there is voltage there, then look for a reset button on the thermal cut-out; if there is one, then press it (with power off) and try again; if not, then the thermal cut-out is suspect.
If no voltage at the thermal cut-out, then check at the input of the pressurestat; If no voltage at the input of the pressurestat, there may be a bad splice, switch, or wire; if there is voltage at the input of the pressurestat, but none at the output (which goes to the overtemp cut-off), then the pressurestat isn't closing the circuit.
Some pressurestats have three contacts - most applications need only two. If one contact is bad, the bad circuit can be moved to a good contact.
Good luck!
LMWDP #331
allon
Postby cannonfodder on Sat Sep 24, 2011 11:21 pm
Sounds like a water reservoir low switch problem. There is a little micro switch under the water reservoir, so when the tank gets low the springs on the base will raise it and disconnect the safety switch. That will kill power to everything. You can check the switch with a continuity meter. I dont remember if they are normally open or closed. You will get continuity in one position and no continuity in the other. If you get nothing at either switch position, then you switch is shot. Could also be 50 other things but I would start there.
cannonfodder
Postby allon on Sat Sep 24, 2011 11:51 pm
Or it could be that.
I should have noted that I have no experience with this particular machine, but was just throwing out generic troubleshooting for a generic machine.
LMWDP #331
allon
Postby JitterBug on Wed Sep 28, 2011 7:18 pm
Thank you allon,cannonfodder.
JitterBug
Postby allon on Wed Sep 28, 2011 10:36 pm
Don't leave us hanging!
What happened?
LMWDP #331
allon
Postby JitterBug on Thu Sep 29, 2011 8:16 pm
What happened,nothing as of yet.Looks like im going to be using my Elektra MC for a while until I figure this out.
Thanks again.
JitterBug
Return to Espresso Machines
