First, when I emptied the boiler I could only get about 0.7L of water out, even when tilting the machine toward the hot water spout. The Bricoletta boiler has an advertised 1.5L capacity, is this normal? Later, I was unable to trick the machine into overfilling the boiler no matter which direction I tilted it. I took apart the machine in an attempt to locate the water sensor. I thought that if I pulled off the wire to the sensor (and thus ungrounded it) the machine would be tricked into to overfill the boiler if the steam valve were slightly open. I tried pulling off what I thought was the water level sensor, but all it did was trip the circuit breaker...
How do I overfill the boiler on this machine?
Eventually I called it quits and just completed the descaling procedures without overfilling the machine. When I was flushing out the descale liquid, I also noticed that there were tiny bits of copper/silver material mixed into the solution. I followed the Dezcal instructions for the amount of water quite explicitly and left the solution inside the boiler for about 4-5 hours total. Is this normal also?
Here are some pictures of the back of the machine.
There are a few possibly relevant pictures located here:
http://ktzero3.tumblr.com/post/10134185591/inside-a-fiorenzato-bricoletta
Thanks in advance!
