Fiorenzato blew via boiler relief valve - No steam / hot water - ¿Steps for diagnosis/repair? w/pic
Postby PietroR on Mon Aug 30, 2010 2:10 pm
Left home for a meal last evening and returned to find a bit of a mess in the kitchen
What caught my attention were bits of ceramic insulation about the place
Thought is
pressure stat stopped cycling
overdrove element
boiler pressure relief valve opened, see pic for displaced insulation
Machine is 24/7
When found at failure
Power indicator was glowing
Pump engaged and water flowed out of the group
Not sure where to begin the process of proper diagnosis
PietroR
Postby another_jim on Mon Aug 30, 2010 2:41 pm
Your diagnosis sounds accurate, but incomplete. If the Pstat jammed and the safety valve opened, the boiler will subsequently refill and cool somewhat, so the vale closes. Then the cycle will repeat until the tank empties. At this point the heater either burns out or a thermal protection device shuts the heat down.
This means the first step is to check the heater -- reset any safety devices, replace any thermal links and check the continuity of the heater. Once that is done, the boiler should heat up. If the boiler overheats, you will need to try adjusting or exercising* the pstat. If that doesn't work, it should be replaced.
* sometimes the membrane freezes and it can be unfrozen by exercising it, i.e. pushing it back and forth using a toothpick from either the steam end or the switch end.
another_jim
Postby PietroR on Mon Aug 30, 2010 4:16 pm
Thanks
I have
(with power disconnected and water supply off)
Cleaned up the insulation mess
Opened the Gicar box to look at the boards, no visible burning
Measured 7.3 across the element
Reset a fuse in line with the p-stat, blue arrow points to it in pic
Restarted machine and all is functional
PietroR
Postby another_jim on Mon Aug 30, 2010 5:34 pm
The thermal fuse tripped, and no harm done. You will need to keep an eye out for the pstat, especially if it is a Mater or Ceme, since these are prone to sticking, and once they start, they keep doing it at increasingly frequent intervals.
another_jim
Postby PietroR on Mon Aug 30, 2010 6:34 pm
Beautiful
Replacing Pressure Stat
My local parts guy, Bill, has a Sarai and the machine has space for it under the hood
Now for some new insulation
PietroR
Postby erics on Mon Aug 30, 2010 7:01 pm
I would not go so fast on that insulation.
Now you can correct me as I type :) but your pstat, whether it be a model a,b, or c, controls a secondary relay (mechanical, not SSR) which does all the "connecting" to the heating element. Yes, a Sirai pstat can handle the current for the Fiorenzato directly but this would require some electrical know-how which you may/may not have.
It MAY very well be that this secondary relay is the problem child.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby another_jim on Mon Aug 30, 2010 8:23 pm
In my admittedly limited experience, SSRs either work all the time or they don't work at all; they don't fail intermittently. If the unit ran after Pietro's repair, this would seem to clear the SSR as the suspect.
another_jim
Postby erics on Mon Aug 30, 2010 8:48 pm
Correct.
But he has a mechanical relay AFAIK.
Skål,
Eric S.
erics
Postby another_jim on Mon Aug 30, 2010 9:57 pm
Ah. then its worth checking if the contacts are carbonized. Arcing can freeze them together.
another_jim
Postby PietroR on Tue Aug 31, 2010 12:04 am
You can see the relay, Siemens 5TT3 984 (no longer produced), to the right in the above photo
It moves freely, I will try to peer inside
http://support.automation.siemens.com/WW/llisapi.dll/csfetch/6006460/505078910DS01.pdf?func=cslib.csFetch&nodeid=6006461
PietroR
Next
Return to Espresso Machines
