by nixter on Sat Aug 29, 2009 4:15 pm
I've had my Oscar for 1.5yrs now. I've pulled the odd extremely tasty shot here and there but the signal to noise ratio was very low. For the last couple months I've been using the La Scala Butterfly that my work has and I hadn't even touched Oscar until yesterday. I've been able to pull consistent, shot after shot at work, each one wonderfully more drinkable than 99% of what I was creating at home. I was all ready to sell Oscar and upgrade to a traditional E61 HX. The Oscar is an HX but just not the big shiny e61 variety. Now in the past in order to try and increase my success with Oscar I'd adjusted the boiler temp, and adjusted the max brew pressure by way of installing a cold water opv, and tried to hone in on the ideal flush, pull, flush, pull routine to no avail. I have a good chunk of change invested in various liquid filled gauges and brass fittings. About the only thing I hadn't tried was rented the Scace, that was next. Well I may have finally figured Oscar out.. or at least what works for me. Last night after work I decided play around with the boiler temp again. I tried going even lower as that seems to be the trend among HB'ers. No dice. Ok, let's go the other direction and crank things up to about 22 psi or 1.5 bar. Bingo. Flush plus 150ml and tasty espresso! again, and again, and again! I think that because Oscar is a smaller HX with less thermal mass she is more prone to fluctuation. By increasing boiler temp she rebounds much quicker to a point where the flush gives repeatable results.
The other thing I did was give a proper clean to the dispersion screen. I'd done this before but hadn't really taken a good look in the light. Anyhow there was plenty of crud around the edges of the holes in the screen so I soaked it overnight and this solved the uneven extraction problems I was having as viewed with my naked PF. I have noticed that after cleaning the group gasket that removing the pf is really hard. Will this improve or can i season it with something?
