www.zokacoffee.com: you're original, drink like it - single origin & artisan coffee
Fast Bezzera Free Flow rate - Page 2
Postby AndyS on Fri Jan 02, 2009 10:48 am
erics wrote:a good friend who has a Quickmill Vetrano (original owner, excellent shape) flows 497 ml/min in a free-flow test.
Hi Eric:
JOOC, what does your friend think measuring a full minute of flow will tell him that a 10 sec measurement won't?
-AndyS
VST refractometer/filter basket beta tester, no financial interest in the company
AndyS
Postby erics on Fri Jan 02, 2009 1:21 pm
And Happy Holidays to you.
I know that you are an advocate of the "10 second - water debit" parameter and, way back, I researched the alt.coffee archives to understand the background info. I certainly have a lot of respect for someone who takes the time to contribute to the various coffee forums (Al Critzler(?)) but my interest dimmed a little when I read "As has been explained to me, acceptable water debit through . . ."
http://groups.google.com/group/al...4/fb226db4ea9f8deb
Having observed several espresso machines in both the home and cafe environment, I saw almost instantaneous flow when the switch was depressed or the lever actuated and that tilted me in the direction of measuring flow over a longer period of time for the sake of accuracy. I positively agree that there probably exists instances and/or machines where one would want to take into account the ramp-up as a trouble-shooting tool but in the posts I've seen here, the problem centered around flow from a tired pump or an incorrectly adjusted valve and I was always comparing their numbers to those published by Ulka (now CEME), Fluid-O-Tec, or Procon.
As regards my friend with the Vetrano, he sorta split the difference :) - he made several 30 second flow runs over a period of maybe an hour and consistently hit 7 ounces on the nose. I just did the conversion.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby PeteF on Fri Jan 02, 2009 7:17 pm
Thanks guys, ok I've pulled a couple of shots now. First went down the drain, a gusher. Second was ok but still having dreadful channeling issues. Haven't used the naked PF on it much, no need to, channeling is as plain as day fairly early into pour. Grrrr! Not sure what I'll try now, I've gradually worked my way up to considerably updosing so maybe try going down in dose/finer grind? I generally find if I can go back to "Italian Standards" on a machine it generally behaves ok, not surprising given those times/dosage/volume are what they're designed for, but I must admit I haven't come across a machine as temperamental as this little bugger!
Yep, got the right Procon in it, well as far as I can tell anyway. It's a series 1, which would be as installed. I was under the impression that the series 1/2/3 had identical specs anyway? The reason I use 30 secs rather than 10 to measure the flow is that, firstly it's what's on my shot timer :lol: More the point, as Eric mentioned, in this design of machine there is no chamber etc to fill when the brew button is pushed. The circuit is charged up to the 3 way solenoid so when the pump comes on/solenoid opens the water simply goes down the final 10 cm (6") to the dispersion block. I just find it easier to accurately measure the larger volume also, but if you divided by 3 it would be pretty much identical to a 10 sec measurement. Eventually I will probably modify to delay the pump activation but I feel that type of thing should be further down the track and my emphasis at the moment is getting the machine/Barista working as designed :shock: i think the pump delay will be a very worthwhile mod on this machine however.
Andy, yes the design of the machine puts the pressure gauge on the inlet to the HX so it will most certainly affect the indicated pressure. I was brewing at 8.5 Bar previously and adjusted the pump to 9.0 to compensate. I did see some graphs somewhere (Illy??) that showed the affect of different sized gicleurs on pressure drop and while I can't recall the specifics I guesstimated 0.5 as covering it. A 0.5 hey, hmm, well now we're pushing it :lol: 0.6 was the smallest drill bits I had but could certainly get smaller, however just want to get everything working as spec for the moment and experiment from there.
Pete
PeteF
Postby erics on Fri Jan 02, 2009 8:37 pm
Bezzera shows the BZ40 as having a 100 litre/hr Procon which I equate to their 25 gph build. The numbers 1322 should be on your pump as per this link:
http://www.proconpumps.com/PDFs/E...20Series%20123.pdf
Yes, the series 1,2, & 3 have same specs but there exists nine different specs within each series.
Skål,
Eric S.
erics
Postby PeteF on Fri Jan 02, 2009 11:02 pm
Thanks Eric, I didn't know about that link, champion! I contacted Procon both here (in Oz) and in the USA a few weeks back about different pumps in their range but neither bothered to reply :x
The pump reads CB1305BLF and G2244. What is presumably the build date on the reverse side is 09/96 which coincides with the only other thing I can date, the start capacitor on the motor, also coincidentally 09/96. I would say it's the motor that came with the machine. It could well be that the pump is getting to the end of its life but I can't see that causing channeling issues or high flow. I thought you may have been on to something there though, oh well :(
PeteF
Postby AndyS on Sat Jan 03, 2009 12:57 am
erics wrote:Having observed several espresso machines in both the home and cafe environment, I saw almost instantaneous flow when the switch was depressed or the lever actuated and that tilted me in the direction of measuring flow over a longer period of time for the sake of accuracy. I positively agree that there probably exists instances and/or machines where one would want to take into account the ramp-up as a trouble-shooting tool but in the posts I've seen here, the problem centered around flow from a tired pump or an incorrectly adjusted valve and I was always comparing their numbers to those published by Ulka (now CEME), Fluid-O-Tec, or Procon.
Perhaps we're talking about two different issues. The 10 sec water debit is mainly concerned with quality of extraction. Your 1 min flow test is about whether the pump is operating properly. Seems to me the OP's is with the former, not the latter.
-AndyS
AndyS
Postby PeteF on Sat Jan 03, 2009 3:16 am
Andy, can you please elaborate in what you mean by, "The 10 sec water debit is mainly concerned with quality of extraction." By this do you mean the time of pre-infusion before full water flow is achieved? In other words, you would really have to look at both the 10 sec and 30/1 min figures for a full account of what the machine is doing. Having said that, in a machine such as the BZ40, there is little proportional difference between the two ie 30 sec volume is pretty much exactly 3x 10 sec volume.
Incidentally I do notice on the pressure gauge a longer time for full pressure to be applied, though it's still not a huge period of time. Overall, I feel the 0.6mm gicleur will be a positive move. Also, I have been out and have critically low coffee levels (again), but did pull a shot as promised much closer to the 14g "standard" obviously with a finer grind. Certainly a better "quality" shot and showed promise. ... mind you I was looking at the amount of head-space on the puck and was thinking OMG I could do laps in there, but it did seem to show potential :lol: Guess the Italians know a thing or two about coffee after all!
Pete
PeteF
Postby AndyS on Sat Jan 03, 2009 2:35 pm
PeteF wrote:Andy, can you please elaborate in what you mean by, "The 10 sec water debit is mainly concerned with quality of extraction." By this do you mean the time of pre-infusion before full water flow is achieved?
Yup, the 65-90ml/10 sec is about saturating the puck before you blast it with full pressure. But such a machine will require a little more careful management (water treatment, descaling, etc) because the small gicleur will tend to clog or scale up more easily. The payoff is more even extractions, less channeling.
Consider that the old Starbucks Lineas were set up with minimal flow restriction (200-350ml/10 sec water debit) so that maintenance issues were minimized. Since Starbucks had little interest in serving quality espresso, a little channeling (or a lot) was OK. Newer LM models (GS/3, GB/5), sold to more discerning customers, have low water debits to maintain puck integrity. On the old machines, liquid espresso appeared at the portafilter within a couple seconds. It was all about minimal maintenance and maximal shots per hour. On the new machines, it normally takes 5+ seconds for liquid to appear.
PeteF wrote:In other words, you would really have to look at both the 10 sec and 30/1 min figures for a full account of what the machine is doing. Having said that, in a machine such as the BZ40, there is little proportional difference between the two ie 30 sec volume is pretty much exactly 3x 10 sec volume.
From my point of view, if the pump isn't shrieking (from cavitation, bad bearing, busted vane, etc), and you can adjust the bypass so the pressure gauge reads 8-9 bars while you're pulling a shot, then the 10 sec measurement is all you need worry about.
PeteF wrote:Incidentally I do notice on the pressure gauge a longer time for full pressure to be applied, though it's still not a huge period of time. Overall, I feel the 0.6mm gicleur will be a positive move.
As others have suggested, if you're still dissatisfied you can try a pump delay preinfusion. And if that isn't enough, re-drilling the dispersion block might help a lot. You can always buy a GS/3. :)
-AndyS
AndyS
Postby PeteF on Sat Jan 03, 2009 2:59 pm
G'day Andy, off the shelf the BZ-40E wasn't (indeed isn't as they're still sold) exactly an entry level machine (well unless you're talking commercial machines of course) and is capable of producing very good quality espresso. Clearly there are better machines available however it shouldn't just channel as a "norm". There will definitely be things I will be able to do to this machine to make it even better however. Nevertheless that's for the future. I've had a look at the pucks coming out and there are no obvious holes in the puck as there were before so hopefully I'm getting somewhere.
I'm pretty sure mechanically the machine is now running 100% but that still leaves normal machine adjustment variables (brew pressure and water temperature), Dosing variables (amount/grind), and Barista technique. Unfortunately with so many variables it's difficult not to begin chasing one's tail, however I want to eliminate as many of the objective variables as I can before starting to change more obscure factors.
Unfortunately, as with any new install, many things are changing in a short space of time and it can be very difficult to track down when something starts running off the rails. One of the things was a change of grinder, from a Rocky to the Mini E, and there is no doubt I'm now getting more channeling with the Mazzer which is more than a little frustrating/disappointing to chase down why. At least I'm a bit happier with the rate of water flow now, as it did look very excessive previously. Whether it was contributing to the channeling issues, well ...??? :?
Pete
PeteF
Postby DavidMLewis on Sat Jan 03, 2009 10:08 pm
PeteF wrote:A 0.5 hey, hmm, well now we're pushing it :lol: 0.6 was the smallest drill bits I had but could certainly get smaller.
I'm old enough to remember carburetor jets. I'm fairly certain that they weren't drilled to size. I believe the final sizing was done by testing against a pressure/flow meter. I'd be very surprised if gicleurs aren't manufactured the same way. What I'm saying here is that something you made with an 0.6 mm drill bit might very well flow significantly more water than a pukka piece. The commercial ones seem to have either 4x0.5 threads or 6x0.7 ones; why not build an adapter for a commercial gicleur that would be much easier to machine?
Best,
David
DavidMLewis
PreviousNext
Return to Espresso Machines
