Time for an update. If you have read the previous posts, you know I moved the machine to the kitchen to fill and pressure test. Then I realized the boiler had a ruptured HX.
But here are a few more photos of the machine in my kitchen
Looks a little better than it did when I picked it up...
There is still hope for the machine. We are looking for a boiler (so if you know where I can get one speak up) but I discovered something. I was under the impression that the heat exchanger was one large chamber that fed both groups. When I disconnected the HX input lines I had no pressure in the left group. When I unscrewed the right group, I got a spray of water. It was still pressurized.
So I got to thinking, that should not have pressure in it, unless each group has its own HX. A quick email to Barry and he confirmed. So, as long as the right group HX is intact, there is still life in the frame. I am going to cap the left HX input and pump supply and just use the right group for now. I will have the worlds only single group machine with a 12L boiler.
I should call this thing the phoenix because it keeps rising from dead. It was pulled out of service once, and came into Daves possession. Then it sat around for a while and was destine for the dumpster when he gave it to Barry where it sat some more. Then it came into my possession (another Dave) went through the rebuild, made it to my kitchen, then headed back to the workbench, possibly to never see the light of day again. Now it may end up back in the kitchen this weekend.
