Faema E61 three or single phase
Postby cyphr39 on Wed Jun 01, 2011 1:58 pm
I recently bought a Faema E61 legend how do I tell whether it is a single or three phase machine ?
cyphr39
Postby JonR10 on Wed Jun 01, 2011 2:26 pm
Single phase 220V generally uses three wires (two "hot" and one ground).
Three-phase power requires 4 wires (three "hot" and one ground)
A three-phase connection may actually have 5 wires (three "hot", one ground, and one neutral).
The neutral wire is optional...
See this : http://www.3phasepower.org/3phasewiring.htm
Jon Rosenthal
Houston, Texas
JonR10
Postby jpboyt on Thu Jun 02, 2011 12:00 pm
The Faema can be sourced from either 1 phase or 3 phase. With correct voltages of course. Difference is in how the wires are attached to the main switch. Faema manuals show the different voltage and phase combinations in the install section.
James
jpboyt
Return to Espresso Machines
