Faema Compact S Restoration Log and Questions
Postby frankmoss on Tue Feb 23, 2010 12:36 am
My new/old Faema Compact finally arrived! I've managed to take it all apart and start cleaning pieces.
Before:
frankmoss
Postby jarviscochrane on Tue Feb 23, 2010 10:53 am
Frank, looks like fun. I am nearing completion of an Auto model and have found this machine to be fairly easy to work on with good availability of parts and information. If you need reference pics check here. More to be added shortly. I also have parts and user manuals if needed.
Were you able to test it before taking it apart?
jarviscochrane
Postby frankmoss on Tue Feb 23, 2010 2:27 pm
Thanks! Your pics should be very helpful.
Unfortunately I wasn't able to test it but I was told by the previous owner that it worked. Did you decide to bypass the water softener?
Also, I've been able to determine that it's a 1994.
frankmoss
Postby frankmoss on Wed Feb 24, 2010 8:04 am
So, I've got most of the parts clean and I'm waiting on new gaskets, etc to be delivered. In the mean time, I reassembled most of the machine to test the pump. When I turn on the power, the pump comes on after a couple seconds and starts filling the HX. Shouldn't it fill the boiler? What could be causing this?
frankmoss
Postby frankmoss on Thu Feb 25, 2010 3:07 pm
Scale in boiler before cleaning:
Pipes and boiler after cleaning:
frankmoss
Postby danetrainer on Thu Feb 25, 2010 5:34 pm
I rebuilt one about 3 years ago...the push button on the front will fill the water to reach the proper level
in the sight glass window...after that it will maintain its water debit.
danetrainer
Postby jarviscochrane on Thu Feb 25, 2010 6:11 pm
You can stop the autofill by grounding the wire going to the top of the sightglass probe. When this circuit is open, it indicates the water level is low and tries to fill until the circuit is closed when the water level touches the probe. Ensure the heating element is disconnected when you do this.
jarviscochrane
Postby frankmoss on Fri Feb 26, 2010 1:20 am
I figured it out. There was a piece of scale blocking the water inlet so that no water could enter, even from the manual fill button.
Now, I'm waiting on parts to come in. More pictures to come
frankmoss
Postby frankmoss on Wed Mar 03, 2010 10:24 pm
I've got the machine put back together and working (pics coming soon). The first shots I've pulled are very oily and don't have a lot of crema. Does anyone know what might be causing this?
frankmoss
Return to Espresso Machines
