by Stuggi on Mon Dec 07, 2009 5:36 pm
Trivia; all the blind plugs you see on that valve is typical for Italian manufacturers, old Weber carburettors for instance have the same thing, plugs and double levers, fasteners etc. It's probably what made them so popular with tinkerers like myself, you can adapt them infinitely. With Webers it's quite interesting, as the carburettors were designed for a specific model, but still they had all these extra fittings (which are kinda useless BTW since they use 13mm metric thread for hose fittings and such, nobody makes fittings like that), but for these valves it's usually meant so that you can adapt the valve to fit a wide spectrum of machines.
Sebastian "Stuggi" Storholm
LMWDP #136
