by number9 on Fri Jul 29, 2011 7:10 pm
Ok, been reading this site and a few others all night and day. I have a eh, 6 or 7 year old Expobar office lever. It has given me a few problems in the past, but now I have a real problem. Here is what happened:
Cleaned the machine as I always do last night. Backflushed it, then ran the hot water so I had some hot water to clean the portafilter parts with.
Turned off the machine.
Came in later, turned on the machine.
I noted that the pump did not go off as it normally does after I pull water, eh, sometimes it does not.
I then noted that the machine was hissing, like the vacuum valve was leaking, and I had no pressure.
Turned off machine.
Got up in the morning, turned on machine.
Pump ran continuously and would not stop.
Turned off machine.
Came in today, after reading a lot.
Took apart vacuum valve and cleaned it. Reinstalled.
Took the autofill solenoid valve apart and cleaned it, although it looked really clean.
Reinstalled.
Turned on machine. Started to heat, no hissing, this looks good.
Pulled a shot with no grinds to see if it works, water comes out.
Turned on hot water want, water comes out.
Now, pressure goes to zero, pump kicks in, and it will not stop pumping.
Turn off machine, let cool, tear apart solenoid again and reclean, reinstall.
Turn on machine, pumps continuously. Checked coil of solenoid, looks good at 250ohms.
What could be wrong with this machine? I will note that when it is pumping continuously,
the little overflow spigot to the reservoir under the portafilter is spitting out water.
I got nothing. This machine irks me, been broken many times before... I think I
want to fix it to get through the weekend and get a new machine, but right now
I am not sure where to turn. Any help would be appreciated.
Thanks.
