I BELIEVE the correct size is AS-11 available at any good hardware store.
Wow...I am beyond amazed you know that.
Dan referenced an article earlier that goes into great detail explaining how this earlier version of the Expobar opv is basically useless as a means of controling brew pressure. I believe it said that you couldn't get the pressure below 10 or 11 bars with one of these...which is why I was asking about replacement instead of repair.
I'm just making an assumption...but it would seem that the springs in my opv have also likely reached the end of their usefulness. I understand that replacing the gasket on the set screw would stop it from leaking out the top...but I don't see how replacing that gasket would stop the constant dripping from the vent spout on the front of the machine. Is that not an issue with the springs and/or balls not completely sealing off the valve chambers?
Don't get me wrong...I would much rather spend $2 on a few springs and a gasket than $50 on a new opv. However, I would rather not waste my time combing the shelves at the hardware store if the thing still won't get me down to 9 bars after it's restored back to "like new" condition. To be sure, I want to stop the leaks...but I also want to end up with a valve that is functional for managing brew pressure.
So repair or replace...your thoughts.
I'm pretty sure I could find suitable replacements for the set screw gasket and spring in a local hardware store. But I'm not so sure about the other spring that's in the horizontal section of the T...it's quite small and delicate.
