Expobar Office Leva II Parts
La_Terza
#1: Post by La_Terza »
Hey everyone,
I'm fixing up an Office Leva II (DB) but am having difficulties locating the replacement parts online.
Is there a website that carries Expobar parts?
If not, does anyone know what other part would work in the place of the original brew boiler temperature sensor? I see loads of them on espressoparts/chris coffee but don't know which would properly fit the boiler.
thanks in advance.
CSME9
#2: Post by CSME9 »
This company sells a lot of Expobar machines, I believe they are the US distributor & they may be of help.
https://www.wholelattelove.com/
Headala
#3: Post by Headala »
I've bought quite a bit of Expobar parts from WLL. As long as you know what you need, it's quite easy to chat with them.
I would download the Leva II/Brewtus parts diagram and just give them the part numbers that you need.
ira
#4: Post by ira »
I don't know if WLL carries it any more, depends on the generation. If not, I believe it might be this:
FURNECO 905-333-6508
controller ako 13120 /01
thermocouple ako 14901 nic
http://www.furneco.com/
Ira
La_Terza (original poster)
#5: Post by La_Terza (original poster) »
Headala wrote:I've bought quite a bit of Expobar parts from WLL. As long as you know what you need, it's quite easy to chat with them.
No dice at WLL. Tried the other suggested source but the link/portal to AKO parts is dead? http://www.furneco.com/english/temperature.html
Here is a link to the manual http://www.expobar.de/EXPOBAR-Downloads ... 100713.pdf
The part in question is on page 17 - Part #9
Unfortunately, it doesn't provide any specs making it difficult to find a non OEM replacement. Would any temp prob work as long as it fit?
I have some taps (both SAE and metric) that I could use to get an idea of the hole size/thread pitch but would have get some of the plumbing out of the way first.
Odd thing I noticed as I was looking through the manual. The machine has some SAE parts even though it's made in Spain.
#6: Post by La_Terza (original poster) »
ira wrote:I don't know if WLL carries it any more, depends on the generation. If not, I believe it might be this:
Ira
I did a google search using the part numbers you listed above and this is what I've found....
http://www.ako.com/en/industrial-refrig ... ccessories
The thermocouple you suggested (ako 14901) seems rather different from the one I need. It doesn't come with a fitting to connect to the boiler or a probe long enough to reach the water though I could be wrong.
#7: Post by La_Terza (original poster) »
This is the closest thing I could find but it's overseas.
http://www.eevad.com/eevad/pieces-detac ... anguage/EN
ira
#8: Post by ira »
La_Terza wrote:The thermocouple you suggested (ako 14901) seems rather different from the one I need. It doesn't come with a fitting to connect to the boiler or a probe long enough to reach the water though I could be wrong.
That's the one used in a Brewtus if you have the same controller. It's a Platinum RTD, not a thermocouple. You have to pull it out from the tube and then push in the new one with heat sink goo. Or that's how I remember it being done by the other members of the Brewtus list.
Ira
#9: Post by La_Terza (original poster) replying to ira »
Gotcha. The machine came to me without the RTD or the fitting which connects into the tank. I wish the tech who had worked on this machine prior to me getting it had kept the part with the machine. This is why I never throw away bad parts until the issue is fixed!
The temp controller is a Giemme.
ira
#10: Post by ira »
Isn't the gimme an autofill box, not a temp controller? Is the temperature/pressure possibly just controlled with a pressurestat? Is it single or dual boiler?
Ira
Post Reply
