by erics on Mon Oct 04, 2010 9:53 am
The way I read the electrical diagram is that the default position of the internal relay is to provide continuous power to the heating element (other than pstat operation). So, a failure of the relay would not typically cut out power to the heater. But, an original relay failure would disable the autofill function and that is why you have the new, external relay.
With the machine unplugged, I would take a real close look at the replacement relay to try and detect some OBVIOUS problem. If you want a blank diagram of the circuit, email me: erics at erols dot com.
