Expobar Brewtus IV PID settings and water temperature
Hi,
I came across a document regarding certified espresso (http://www.espressoitaliano.org/files/F ... _lq_it.pdf) and I want to reproduce the same on my Brewtus IV.
I notice that I cannot go as low as the recommended 88 degrees C for the water exiting the shower screen on the PID (well actually I do not know what temperature the PID is referencing). How do I setup the machine? What are recommended settings for the PID (offset, P,I,D, temperature) and how does that relate to the recommendation. I thought 88 degrees sounded low given 95 which was defaulted on the Brewtus IV, but reading on several roasters pages (Italian/Spanish) that seems to be a recommended brewing temperature.
Any thoughts?
And one point is that I do not have any thermometer or any other fancy device to actually measure and set it up based on that so please come with some input based on your experience
Any thoughts?
I also wonder if the PID's show the brew temp in shower or the temperature of the boiler...
I mean i want to know if i set the PID to 93C. The water touching the coffee is 93C ?
any help would be great...
- erics
- Supporter ★
All the info on the Expobar Brewtus you could ever want: https://wiki.wholelattelove.com/Expobar ... 26_Manuals .
The PID is measuring boiler temperature with a user adjustable offset built in to the controller. It is INTENDED that the display show you the temperature of the water presented to the coffee.
Then I deduce that the Expobar is incapable of preparing certified espresso, seems incredible
It's certainly not incapable, but without a Scace there really is no way to know what it's doing. So many people use and are happy with the espresso from a Brewtus, but the early npn-PID version and the later PID versions that I am having trouble understanding your concern. Just adjust it till the espresso tastes good. Isn't that the goal anyway.
Brew 101: How to Adjust Dose, Grind Setting, and Temperature by Taste
Ira
Ira
You are absolutely right, and the coffee tastes great. I'm aiming for a taste profile like in Rome and that is what I seem unable to get
Then talk about the difference between what you get and what you're looking for so people can suggest direction.
Ira
Ira
I have a neutral coffee which is velvet smooth. My memory tells me that the Italian coffee had a similar texture but stronger (more) taste yet no bitterness
- Hudson
Try pulling a more ristretto style shot? Less yield might give you the taste you want. Espresso 101: How to Adjust Dose and Grind Setting by Taste
LMWDP #534
