Expobar Brewtus III - pressure drop during extraction
Setup: Expobar Brewtus III, age 7 years.
My brew pressure is dropping off during the extraction. It sounds like the pump is turning off, only to turn back on after a while. Flow rate is OK, and subjective espresso taste is getting worse.
See the video:
Brew pressure slowly rises to about 9 bar, and it drops down to 5-6 bar before the pump turns back on, or at least gets louder.
[youtube]Qo2G7L7ZEaY[/youtube]
https://www.youtube.com/watch?v=Qo2G7L7ZEaY
Is this pump failure (as described there Inconsistent brew pressure), or more an OPV related issue?
See the video:
Do you have the same behaviour if you run the pump with the blind disc in place?
Bert
