Another user of appia did it, and it doesn't seem to bear any problem.
Javacat wrote:Luc, the restrictors you need are a .5 for the flow meter and a 1.75 in the group (can be ordered from Nuova Simonelli). Once you swap these out your group will run cooler by about 2-4 degrees. I had to drop my pressurestat down to about 1.1 also, but now I consistently get 201 -202F at the puck as opposed to the 203 -205F previously. I use a flush and go routine - I flush about 1-1/2 - 2oz then pull my shot. Hope this helps.
-Matthew
But for now, I won't modify it neither as I don't have any device to measure temperature to rely on. I've seen on your blog that you manage to have a pretty consistent routine.
Any difference with the K10 for now?
