by another_jim on Mon Dec 22, 2008 7:22 pm
I have a Jaeger replacement as well, and it's worked about 8 months now. The Mater on my second machine has had on and off use for about 3 months, and is still working.
The facts so far:
1) Both Mater and Ceme pstats have failed, up to now, no Jaeger has, but none have been installed for more than a year.
2) There's no sign of scale on many of the failed stats, so lime scale is not the culprit
3) Some people have had machines for many years with no premature failures (if a stat fails after 5 years, it isn't premature, but ordinary wear and tear)
Just guessing here, but I still think the problem is debris left from the construction of the machine finding its way into the pstat which is at the lowest point of the machine. If this is the case, in the affected machines, one or several pstats will fail early in the machine's career, then the problem will clear up. There was a rash of these problems, involving both Ceme and Mater pstats, around the time I posted the review. Was the culprit a new lathe at the Elektra plant?
