by JmanEspresso on Tue Mar 16, 2010 2:26 pm
Hey no problem, just glad I can add some useful info now and then!
As to what would happen if you do NOT bleed false pressure right away, ie: turning the machine 40mins in advance, but not bleeding any pressure... I think nothing happens, the machine doesn't heat up. Water out of the group, and the group itself would be cold(or room temp), and once you open the steam arm, pressure would drop, and then the machine would begin to heat up. I could be wrong... of course
I almost bought the Oscar.. it was a Friday, and Mary at Chris Coffee could tell I was iffy, so she suggested to call back on Monday to place to order(think over the weekend). Anyway, I ended up going for the Anita, but the above paragraph is what Mary told me would happen, if I turned on the machine, and didn't bleed the pressure right away. She also suggested that(if I bought the oscar), that I let it heat up for ~10mins, open the steam knob briefly, then close it, as opposed to opening the steam knob from the get go, and closing it when steam comes out. She mentioned it would go a bit quicker letting it do the initial heatup to false pressure, with the steam knob closed. But, after describing that, She said that, if I left it on 24/7, its never an issue, and that the last couple oscar owners she sold too, leave their machines on 24/7, because of that very issue.
