Adrock wrote:Thanks for the advice. I had already planned on spending quite a bit on either a Macap or Mazzer - I have a Solis Maestro Plus now for FP, but I understand that won't cut it for espresso.
The La Pavoni Europiccola looks quite nice. The additional crema and "smoother" shot quality of levers is very attractive. I have a few more questions about it if you don't mind:
-How does it perform head to head vs. a Silvia for shot quality?
-I understand that it overheats after 3-4 shots. Is the temp stability consistently good before it overheats?
-Is it less "finicky" than the Silvia?
-Is the lever pressure a difficult variable to master? Will it make a more difficult learning curve for the machine?
You really don't need to spend hundreds on a Macap or Mazzer when a $50 or $75 hand grinder will do very well. I'd spend that money on the machine and buy a new machine instead of a used one which may need work. My recommendation on this point is not flying in the face of the wisdom here, namely, that the grinder is critical. I agree with that advice. Rather, I'm saying that a Kym or Zassenhaus hand grinder, in good condition, with sharp burrs, is a very good grinder indeed. You have to ask yourself, What am I more interested in, making delicious espresso or in owning shiny power-toys?
Consider the Silvia temp-surfing and learning the manual-lever's pull a wash in terms of learning curve. You don't have to pull very hard on the lever; you want a firm steady pull.
Regards
Timo
