by dsc on Sun Mar 22, 2009 3:46 pm
Hi guys,
well it was a bit of fun, but not entirely. I've installed the pressure transducer this morning and oh boy it takes a while to get a proper read out. With a blank disk in the PF it took around 5-6s to get a read out of 8.5bar (pump setting). Don't know why it works like this, but I'll be switching to a normal dial gauge sometime in the future. I'd love to get a proper panel-install high precision one, but sadly the cutout in the front panel of the Elektra is 60mm and the industrial standard is 63mm:| And even if I somehow manage to fit one in I will have to re-route the hot water pipe at the back of the gauge as it runs straight through the middle where a normal single dial gauge would have it's entry.
All the fun ended when my machine started acting strange and the autofill function began to misbehave. I have no idea why it happened but it was autofilling for a very long time after I used around 200ml of water from the hot water line. The pump was running for around 30-40s and suddenly stopped, so I though what the hell maybe the boiler was way below level? Tried it again and the same thing happened although this time I almost shut down the machine as it was seriously taking too long. On top of that there was almost no water coming from the group, as if it was running on inline pressure all the time (even though the pump was engaged). Tried pulling a shot and even managed to get something out, although I knew it wasn't right. The boiler pressure wasn't raising and everything seemed to work normally (except for the weird autofill and group flow behaviour). I turned the machine off and partially drained the boiler through the hot water tap, checked the level sensor, descaled it (it was clean but I did it anyway) and put it back together. After turning it on it started filling the boiler again, but this time it wouldn't stop for a good minute or so. When it finally de-energised the pump all the LEDs above the buttons started flashing and it wasn't doing anything. So I removed the pressure transducer, put the pipes back as they were and checked the level sensor connections (on the cable and on the PCB behind the buttons). All looked ok, so I turned it back on, but forgot to turn the inline water supply:O This means I ran the pump dry for a few seconds after realising how stupid I am (brand new pump) and gave myself a proper whack on the head to pull myself together. Fortunately it looks like the pump is alive and kicking, probably minimal (or no) damage done to it. It did have around 2m of pipes on the inlet (+the water filter) all filled with water, so I guess that somehow saved my ass (and it only ran for a few seconds). It's not making any strange noises and seems to work well giving proper pressure and not leaking.
I don't know what caused that strange behaviour but I do know that I need a dial gauge, a new proper long hose to connect the machine to the JG fitting I have on the end of the pump tubing and I still have to fit the TC on the boiler.
Regards,
dsc.
