The old washer drops easily into place.
The new washer doesn't fit by about 1mm or so. I've offset it from the hole so you can actually see the difference.
I'll dig through my mess in the garage to see if I can find my calipers...
Mark
Paul wrote:are the ID of the original and replacement washers the same? I've had this issue before and the replacements worked for me. Make sure there is no rubbish on the seats and I bet you'll be fine.
Paul wrote:awaiting your reply, in the meantime, a little thought . . .
sometimes, collapsible copper gaskets are used. These are like hollow o rings that crush to form a nice seal. I wonder if the old ones are like this.
