dsc wrote:So you mentioned something about the insulation working, is it indeed good enough, or not?
It's certainly working since I can put my hand on the insulation, you don't want to do that with a boiler...
If someone else has a Killawatt meter (or equiv) we can compare an insulated boiler vs one that isn't. Now these reading are from a cold start (over night). But they include three double espresso and lots of cleaning. Still the amount of water heated was probably only a couple of cups. The main difference in the insulated vs non-insulated should be the power used to keep it all hot, the amount to heat the system up should be about the same (assuming boiler fill to the same level). Current draw, pump off is 12.1 amps at 116 volts which is 1400 watts during boiler operation.
Power Readings
Time KWatts
0:56 0.41
1:18 0.52
1:49 0.81
dsc wrote:Are you planning to make a naked on your own, or let someone else do it for you? I guess this really depends on whether you have access to a lathe or at least an electric drill with a hole saw bit (something I will use probably).
I'll just go with a hole saw with the unit screwed down to a piece of wood and use my drill press.
dsc wrote: the shot looks a bit blond though
Noticed something this morning during the second shot that I should have been paying attention to, the pressure during the shot was 13-14
OK, find a screw driver and adjust the rotary pump, hmmm, clockwise or counter clockwise, ah, counter clockwise to have less pressure, adjusted down to 10 for now, I'll get it to 9 next time.
A while ago, I posted about the frame and the motor just touching. Indeed, my machine has a loud rumble when the pump is engaged, not the quieter sounds I was hoping for from a rotary pump. I then pressed some rubber padding between the pump and frame and it's a lot quieter. I may need to shim the pump mount (or bend the frame) about 2mm to keep the pump and frame from touching.
Time to finish my second espresso and start taking up ceramic tile from our slab in the bathroom...
Mark
